Grafana 8.0.1 -
I would like to create a rule in Grafana alert where I can use thresholds from a MySQL datasource. I created a PromQL query and an SQL query but I can’t use labels from the PromQL query in the SQL query :
Is there a solution to use a condition in SQL query with a label from PromQL ?
Example :
SELECT threshold, hostname as host
FROM threshold
WHERE indicateur=‘SpaceUsedPercent_threshold’ AND host={{$prom.host }};
