I’m trying to configure an alerting for the percentage between 2 ElasticSearch queries. That should be computed (by ElasticSearch bucket scripts or by any plugin) per bucket. Some ES documents have an “status” (string) field. I’d like to do:
count status:error / count exists:status
I’ve been following MetaQueries plugin and it looks very promising, but it won’t do any alerting right now, because there is no backend plugin.
Just to make clear, I don’t have a problem with the presentation, just the alerting part. Although, it would be simpler to have a solution based on filtered queries or bucket scripts. Right now, we can do it with pie charts and stacked graphs.
My last line of thought is using 2 metrics, 1 is Count of the main query (which solves the denominator part) and 1 with a Sum over a new query.
Thanks,
