Alerting default templates
Can someone point me at the default templates in use so I can use them as a base to modify.
I’m not interested in writing them all from scratch and there doesn’t seem to be a place to get recommended templates like say the way you download dashboards (heaven forbid you made this easy).
All I want to really do is remove the value field but I’d rather not re-invent the wheel to accomplish this.
