Hi all,
I’m using Grafana v10.2.3 and I’m getting stuck using the alerting templates. Trying to form a custom message, and the preview looks good, but all of the variables I put in break once I test the alert.
So in this test message, I just print some basic info, and in the Preview it looks as I expect it to: Good stuff!
However, when I try to send this message to a discord webhook, the message cuts off after the first {{ }} variable. You can see it sends the plain-text then just doesn’t try to fill in the rest of the message
Nothing I do seems to make any difference, I cannot add any info from variables.
Anyone know what the problem might be?
Thanks!
