Alert query result i empty even though it shows results in the graph
hi,
im trying to fire an alert, but the state is always ok.
in the graph it looks good. and in table view it also has data .
tried everything. now im stuck.
query:
with hour_time_series as (
with time_series as (
select time_column
from generate_series(now() - interval ‘7 days’, now(), ‘1 minutes’) as time_column
select date_trunc(‘minute’, time_column) as time_column
from time_series
order by time_column desc
missing_images as ( --the original query from 1.1.0
SELECT date_trunc(‘minute’, au.created_at) as created_at, count(*) as missing_images_count
FROM service.active_urls au, service.active_domains ad
WHERE ad.id = au.domain_id
AND au.created_at > now() - INTERVAL ‘7 days’
AND au.extracted_at > ‘-infinity’
AND au.title IS NOT null
and (au.image_url is null or au.image_url not like ‘https%’)
group by date_trunc(‘minute’, au.created_at)
order by date_trunc(‘minute’, au.created_at)
select COALESCE(mi.missing_images_count, 0), $__time(hts.time_column)
from hour_time_series hts left join missing_images mi on date_trunc(‘minute’, mi.created_at) = hts.time_column
where $__timeFilter(hts.time_column)
order by hts.time_column desc
here is the test result:
tried also testing it with a simpler query, but still query result is empty:
SELECT $__time(au.created_at), count(*) as missing_images_count
and $__timeFilter(au.created_at)
group by au.created_at
