Version: Grafana v4.6.3 (commit: 7a06a47)
The Alert function with “Stack + Percent” Graph doesn’t work for me.
Result of the test Rule is:
firing:true
state:""
conditionEvals:" = true"
timeMs:"0.927ms"
error:"tsdb.HandleRequest() error Missing query definition for non_negative_difference"
It has two simple InfluxDB queries:
SELECT non_negative_difference(mean("value")) FROM "series_a" WHERE ("value" > 0) AND $timeFilter GROUP BY time(10m) fill(none)
SELECT non_negative_difference(mean("value")) FROM "series_b" WHERE ("value" > 0) AND $timeFilter GROUP BY time(10m) fill(none)
I would like to create an alert that send a message after the series_b is below of 60% (if the 100% equal is series_a + series_b.
In another graph, with “normal” display settings, the alert works well on the same series…
Is it possible that the Alert function couldn’t working in “Stack + Percent” display method?
