Grafana v7.5.5 (b5190ee547) -
To send notification from panel configured with template variables. -
By setting the alert on panel -
What happened?
Getting below error when creating alert. The same alert alert works when passing values instead of variable
“alert validation error: Data source used by alert rule not found, alertName=Backend Last Byte Response Time alert, datasource=${datasource}”
Seems like this is an open issue. -
Nope.
