- Grafana v7.2.0 (efe4941ee3)
- What are you trying to achieve?
My alert behaviour is not normal. OK state when it should not be OK - What happened?
I have elastic search query which is looking for data. - What did you expect to happen?
if avg is more than 1 is should be alert. - Can you copy/paste the configuration(s) that you are having problems with?
Why it goes to alert state so many times and why it goes to OK state when it is clear that is still an issue?
In the raw data there is no issue.
Can I have at least some suggestions ?
Data is from elastic search…
