Agentic alerting with Assistant Watchers (The Context Window #08)
Topic: Agentic alerting with Assistant Watchers
Date and Time: 2026-11-26T15:30:00Z (15:30 UTC)
In Agentic alerting with Assistant Watchers, episode 8 of The Context Window, we dig into Assistant Watchers, the agentic alerting feature in Grafana Cloud.
Alert rules are great for the failures you already know about, but some problems are hard to write a rule for. Watchers are always-on agents that check a scoped part of your telemetry on a schedule and use an LLM to judge what they find, so they can catch fuzzy, cross-signal problems a threshold misses.
The episode covers:
  • what Watchers are and how to set one up
  • how a watcher differs from an alert rule
  • how they work under the hood, and how to calibrate them (including auto-recalibration)
  • how a watcher can raise alerts and start Assistant Investigations
with demos in Grafana Cloud. Assistant Watchers are generally available in Grafana Cloud, under AI > Watchers.
Hosts and guests:
  • Nicole van der Hoeven, Senior Developer Advocate, Grafana Labs
  • William Dumont, Staff Software Engineer, Grafana Labs
Watch live: https://youtube.com/live/RwFZoxe5lP4
Links:
