I have a backend datasource working pretty well for my building automation system. Now I’m interested in exploring a little more and making it a little more advanced. I have been studying this API document to try to imagine the possibilities but there aren’t any descriptions for the methods. Here’s what I’ve learned so far. A few of them are documented in the tutorial and examples, but I’ll include them anyway, for completeness.
- setConfigEditor() sets the component that configures the datasource itself - for example, URL to the server
- SetQueryEditor() sets the component that configure each query added to your panels
- SetMetadataInspector() looks like it’s used for displaying statistics in the stats page of the query inspector, but if you don’t provide one it gives you a generic table
- SetQueryEditorHelp() is probably what it sounds like
These are listed in the source is deprecated, so I’ll ignore them
- SetExploreStartPage()
- SetVariableQueryEditor()
- SetComponentsFromLegacyExports()
These have the word ‘explore’ in them so I think they are specifically support for the explorer, but I’m not sure what ‘field’ means here.
- SetExploreMetricsQueryField()
- SetExploreLogsQueryField()
Similarly, these all have “control” in them and I’m inferring that they mean angular controls, meaning you can ignore them if you’re building a React based datasource:
- SetConfigCtrl() - an angular datasource configuration component
- SetQueryCtrl() - an angular style query editor component
but also in the *Ctrl category is this:
- SetAnnotationQueryCtrl()
which is a small mystery. This Document tells you how to enable annotations but it doesn’t mention how this function is used. A few datasources use it but they are all angular. If you want to provide a custom annotation “query control” does it have to be angular?
Lots of assumptions here … if somebody can clear up any of them for me I would be appreciative.
