current grafana version = Grafana v11.1.0
Grafana OSS installed On Premises linux server RHEL 8.9 -
upgrade grafana to v11.6.1+security-01 -
How are you trying to achieve it?’
folowing files/directories were backed up before upgrade - /etc/grafana/ , /usr/lib/systemd/system/grafana-server.service , /var/lib/grafana/,/var/log/grafana/ , /var/lib/grafana/plugins/
grafana-11.6.1+security~01-1.x86_64.rpm was copied to /tmp
upgrade done using command - “sudo dnf localinstall /tmp/grafana-11.6.1+security~01-1.x86_64.rpm”
restarted grafana service
What happened?
admin password reverted to a previous value after an upgrade.
everything else is working fine.
i expected admin password not to be changed to previous value. -
no -
official documents + took additional backup to be on the safer side.
