Hi all,
had tried Grafana 8.3.3 for a while on my Ubuntu 20.04 LTS server successfully.
Yesterday, upgraded to 8.3.4.
Since then, I still can login as admin with my admin password, but Grafana still shows the login button in the lower left corner (and not the admin account picture as so far).
Of course, I cannot edit any dash/panel.
Resetting admin password via CLI to a new one gives no solution.
cd /usr/share/grafana/
grafana-cli admin reset-admin-password admin
INFO[01-21|09:55:30] The state of unified alerting is still not defined. The decision will be made during as we run the database migrations logger=settings
WARN[01-21|09:55:30] falling back to legacy setting of ‘min_interval_seconds’; please use the configuration option in the unified_alerting
section if Grafana 8 alerts are enabled. logger=settings
INFO[01-21|09:55:30] Config loaded from logger=settings file=/usr/share/grafana/conf/defaults.ini
INFO[01-21|09:55:30] Config loaded from logger=settings file=/etc/grafana/grafana.ini
INFO[01-21|09:55:30] Config overridden from command line logger=settings arg=“default.paths.data=/var/lib/grafana”
INFO[01-21|09:55:30] Config overridden from command line logger=settings arg=“default.paths.logs=/var/log/grafana”
INFO[01-21|09:55:30] Config overridden from command line logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
INFO[01-21|09:55:30] Config overridden from command line logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
INFO[01-21|09:55:30] Path Home logger=settings path=/usr/share/grafana
INFO[01-21|09:55:30] Path Data logger=settings path=/var/lib/grafana
INFO[01-21|09:55:30] Path Logs logger=settings path=/var/log/grafana
INFO[01-21|09:55:30] Path Plugins logger=settings path=/var/lib/grafana/plugins
INFO[01-21|09:55:30] Path Provisioning logger=settings path=/etc/grafana/provisioning
INFO[01-21|09:55:30] App mode production logger=settings
INFO[01-21|09:55:30] Connecting to DB logger=sqlstore dbtype=sqlite3
INFO[01-21|09:55:30] Starting DB migrations logger=migrator
INFO[01-21|09:55:30] migrations completed logger=migrator performed=0 skipped=377 duration=1.009675ms
Admin password changed successfully
Resetting admin password to admin gives me the password change dialog, but on save I get the two error messages: " Invalid or expired reset password code" and “Unauthorized”
This happens on latest Firefox (96) and latest Edge (97) browsers. Caches cleared.
Any help available?
