Adjust Fill to be below - not to zero
I have a data series and all the metadata is negative values (rssi from my LoraWAN node).
The fill is to zero, but I would like it to be below the line. I can only find fill below to the other series.
Input will be appreciated
@johans - I have the same concern, but Iā€™m graphing wireless client signal strength. Were you able to resolve this?
