10.2 on server -
Add webpage to a dashboard showing the location of a vessel -
I have created the dashboard, and tried to use the TEXT and HTML selected panel with as a test but the page shows unable to connect. -
What happened?
Page shows as unable to connect -
Display webpage on the dashboard.
I am trying to display the location of a vessel, the actual script i want to use is
This should display the location of a vessel
- Can you copy/paste the configuration(s) that you are having problems with?
Website refused to connect -
