i want to develop a datasouce ,its need to update a file,i want to add a restful api in the go code…use $http to post some data to the go funciton to do some operate, but there always occur this questions
Is this a datasource plugin?
It looks like you are trying to post to the http api endpoint that saves datasource config data (name, url etc.). That is probably not what you want to do.
yes.this is a datasource plugins, i want to upload a file,and read the file content,transform it to json,and write json to a file.put it in the grafana dir, when the panel use the datasource ,.i want to read the json file as datasource
@daniellee i had resolved this problem.thx
