Active Directory Single Sign-On
what is the best way to integrate Grafana to Microsoft Active Diretory with Single Sign-On (no manual ldap)?
Do I need an additional webserver or does it run out of the box?
I read through a lot of docs but I could not find an answer.
Thanks
From the 5.0.0-beta1 release Grafana can use the OpenID Connect support in AD FS 2016 & later, it will be very similar to the Azure Active Directory configuration but the config UI in AD FS will obviously be different.
You can see an example of setting up the server side here https://docs.microsoft.com/en-us/windows-server/identity/ad-fs/development/enabling-openid-connect-with-ad-fs
