Is there support for integrating grafana with datasource that expects Authorization header with Bearer token obtained from Azure active directory
deshevan
1
Have you read the documentation? Could you please explain in more detail what you’re trying to accomplish.
Marcus
Related topics
| Topic | Replies | Views | Activity | |
| OAuth2 authentication with a custom datasource plug-in | 15 | 7855 | September 27, 2023 | |
| Authentication for datasource plugin using Oauth2.0 implicit grant flow | 4 | 1734 | September 27, 2018 | |
| Forward Azure AD token to configured data source | 1 | 825 | August 27, 2020 | |
| ADAL within a Datasource Plugin | 13 | 2015 | April 23, 2018 | |
| Explain Azure AD based authentication in Azure Monitor plugin | 1 | 684 | June 21, 2018 |
