How do I add the following mapping?
if action_code == "%%1537" then "Read Data (or List Directory)"
else if action_code == "%%1538" then "Write Data (or Add File)"
else if action_code == "%%1539" then "Append Data (or Add Subdirectory or File)"
else "Unknown Action"
I can’t see action_code
or Replace all fields
options.
Thank you.
