413 Request too large error
I have the below K6 service in my docker compose file
k6_crud_tests:
container_name: crud_tests
image: loadimpact/k6:latest
ports:
- “6568:6568”
environment:
- K6_OUT=influxdb=https://myinfluxdb:8086/k6
- K6_INFLUXDB_CONCURRENT_WRITES=4
- K6_INFLUXDB_PUSH_INTERVAL=20s
- K6_INFLUXDB_PAYLOAD_SIZE=1000
volumes:
- ./scripts:/scripts
- ./utilities:/utilities
command: run //scripts//Tests.js
I have separate instances of influxdb v 1.8 and Grafana executing and available publicly on our domain. The env values for influxdb is as below
INFLUXDB_DATA_MAX_SERIES_PER_DATABASE=0
INFLUXDB_DATA_MAX_VALUES_PER_TAG=0
INFLUXDB_HTTP_MAX_CONCURRENT_WRITE_LIMIT=0
INFLUXDB_DB=k6
INFLUXDB_HTTP_MAX_BODY_SIZE=0
INFLUXDB_VERSION=1.8.10
I always get the error
“ERRO[0140] Couldn’t write stats error=”\r\n413 Request Entity Too Large\r\n\r\n
\r\n
nginx\r\n\r\n\r\n" output=InfluxDBv1"
I have also used tried using the conf file for influx db and the results are the same
[meta]
dir = “/var/lib/influxdb/meta”
[data]
dir = “/var/lib/influxdb/data”
max-values-per-tag = 0
max-series-per-database = 0
engine = “tsm1”
wal-dir = “/var/lib/influxdb/wal”
[http]
max-body-size = 0
any ideas pls??? Thank you!
Hi @21.prash,
the main reason why you’re seeing the reported error is the following option:
Why did you set it so high? In this way, you’re saying to the output to aggregate samples across 20 seconds and flush all at once. You should definitely use a lower value. The default value is 1s.
You should also consider migrating to the new official Docker image grafana/k6.
I used “- INFLUXDB_HTTP_MAX_BODY_SIZE=50000000” in the influxdb container that resolved the issue. I will also consider removing the push interval variable and the new image.
Thank you!
However, now I get a new issue
ERRO[0833] Couldn’t write stats error=“{"error":"timeout"}\n” output=InfluxDBv1
I have added timeout of 4m…pls see below
let res = http.post(appUrl, JSON.stringify(secretCreationBody),
        headers: { 'Content-Type' : 'application/json', 'Authorization' : 'Bearer ' + token},
        timeout: '4m'
any idea?
