we are looking at a show stopper right now.
Loki: 2.4.1
Grafana: Grafana v8.1.6
Example:
we have 2 queries:
- We want to meassure all incoming events, that occured in a specific range like:
sum(count_over_time(
{app="controller"}
|="here is my incoming event"
[$__range]))
- We want to meassure all successful events, that occured in a specific range like:
{app="controller"}
|="here is my successful event"
[$__range]))
but what we really want is the difference here. if the difference is 0 the software works fine.
What happens:
if we have incomin requests matching Query 1 we get a value.
if we have no successful executions matching Query 2 we get nil (“no data”)
if we calculate query 2 minus query 1 we get “no data” as answer instead of the real difference
we need to observe the difference between these 2 queries and may trigger alerts.
Is there any solution to get this fixed or at least worked around?
Kind regards,
Carsten
Hi there,
I found a workaround that is not beautiful but working:
if you have a query that might lead to “no data” you can use the “or” vecor operation multiplied by 0 eliminating the second query totally but returning a working vector, that represents 0.
For example solving my question from above would look the following:
Query 1 (incoming event) will look like:
{app="controller"}
|= "here is my incoming event"
[$__range]))
sum(count_over_time({app="controller"}
[$__range])) * 0
#just taking all the logs the controller produces and multiplying them with 0
Query 2 (successful events) will look like:
{app="controller", container="controller"}
|= "here is my successful event"
[$__range]))
[$__range])) * 0
- resulting in the final query to get the difference:
#Query 2 minus Query 1
[$__range]))
[$__range])) * 0
{app="controller"}
[$__range]))
[$__range])) * 0
I hope it will help you because this way will not make your alerts unusable
This ugly solution works for me.
Thank you!
I’d like to point out an optimization suggestion for the “dummy query”.
Instead of counting over [$__range]
, it might be more efficient to count over a fixed small amount of time.
Here is the “dummy query” that I use:
{level=~"error"} [5m])) * 0.0)
I also selected the “error” level because it’s where I have the smallest amount of logs.
Kind regards
this will not close until there is a solution for https://github.com/grafana/loki/issues/5074
