I am new to Grafana REST API but I think API endpoint is wrong in Swagger-UI for alert provisioning. As you can see on picture, api is mentioned twice and this endpoint does not exist. Other API endpoints are correctly formed (api is mentioned only once e.g. in GET /datasources).
Grafana version: 10.1.2 OSS (latest)
OS : Fedora 36
- What are you trying to achieve?
I wanted to use Swagger-UI (http://hostname:3000/swagger-ui#/provisioning/RouteGetAlertRules) in order to GET alert rules but I end up with error message{ "message": "Not found" }because endpoint is wrongly formatted (as shown on upper picture).
What happened?
I got error message{ "message": "Not found" }and didn’t get alert rules.
I expect that I will get list of Alert Rules instead of error message.
- Can you copy/paste the configuration(s) that you are having problems with?
I got error message{ "message": "Not found" }. -
Best regards,
ldrascic
