I am setting up the Grafana agent, and looking to collect both Windows system metrics and IIS metrics. I have been following the instructions for windows_exporter
for both:
relabel_configs:
- target_label: job
replacement: ‘integrations/windows_exporter’
relabel_configs:
- target_label: job
replacement: ‘integrations/iis’
Both configurations use windows_exporter
, but it seems that they each require the job
label to be set to their own value; integrations/windows_exporter
and integrations/iis
, respectively.
Is there a way to configure it to use both at the same time?
Hi Daniel
The agent would only allows one definition of an enabled exporter under the integration section.
So I would recommend using the IIS config snippet for the integrations as it involves both the standard Windows integration metrics and also enables the additional IIS collector.
A single job name can be used and it should come up in both IIS / Windows dashboards unless a regex filter has been applied (Which I have checked is not the case for both IIS / Windows integration)
Log scrape configs can be defined multiple times either with the same job names or different ones.
Thanks. I will give it a try.
