So I am new to use k6.io and when I just try to add console.log(‘Hi!’) at the init stage, it seems to be called 4 times. I am quite confused here. Any reasoning why? Because I can’t found the reasoning at Test lifecycle
  / __________ \  |__| \__\ \_____/ .io
INFO[0001] Hi!                                           source=console
  execution: local
     script: script1.js
     output: -
  scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
           * default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
running (00m00.1s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs  00m00.0s/10m0s  1/1 iters, 1 per VU
Of course I am quite happy when I found out setup() only called once
