Hi!
I’m having trouble running a websocket for more than 15 seconds.
The code is from documentation:
const socketUrl = `${resBody.url.replace('https', 'wss')}&id=${connectionId}`;
res = ws.connect(socketUrl, params, function (socket) {
socket.on('open', function() {
console.log('connected');
socket.setInterval(function timeout() {
socket.ping();
}, 1000);
var payload = JSON.stringify({
'protocol': 'json',
'version': 1
socket.send(payload);
socket.on('message', (data) => console.log('Message received: ', data));
socket.on('close', () => console.log('disconnected'));
socket.on('error', (e) => console.log('Error: ', e.error()));
socket.on('ping', function() {
console.log('ping');
socket.pong();
socket.on('pong', () => console.log('pong'));
socket.on('priceupdates', (data) => console.log('PriceUpdates: ', data));
socket.setTimeout(function () {
console.log('Timeout');
socket.close();
}, 1000 * 60 * 100);
check(res, { 'status is 101': (r) => r && r.status === 101 });
and the output:
Run command:
k6 run --vus 1 --iterations 1 --duration 1m --min-iteration-duration 30s live_prices.js
Any ideas? I need to run it for 15 minutes minimum.
