As per the below image you will notice that the values of the metrics do not have any units. Is there any way to apply data units?
Thank you for taking the time to point this out.
There is a feature request in Grafana’s issue tracking system for this (feel free to add a
there to tell us this is something people want). We’re in the middle of a major migration from Angular 1 to React at the moment (partly to make this kind of changes easier to work with), so it’s not something I’d expect to see in the next couple of versions, but improving alerting is definitely something we’d want to do, and like your screenshot nicely shows it’s just bizarre that the values are the raw output from your query.
Thanks for the reply.
Is there any way to find from where the alert_notification.html file is called?
