Using three.js in Grafana plugin
I am trying to make a panel in Grafana with a 3D model in it. To make this possible, I want to use threejs and FBXLoader. I made a file called three_with_fbxloader.min.js that contains three.js, FBXLoader.js, zlib.js and OrbitControls.js. I need all these libraries for the 3D model to work. However, when trying to import this file, I get an error. I have tried to import the file like this:
<script type="text/javascript" src="./external/three_with_fbxloader.min.js"> </script>
inside module.html. This results in the error:
GET http://localhost:8080/external/three_with_fbxloader.min.js 404 (Not Found)
I don’t get why the file is not found, because it is present in the ‘external’ folder and also gets copied to the ‘dist’ folder when running grunt. I also tried to import the file like this:
import THREE from './external/three_with_fbxloader.min.js'
import './external/three_with_fbxloader.min.js'
inside module.js. These statements both result in the error
Plugin Error
THREE is not defined Instantiating http://localhost:8080/public/plugins/grafana-Model-panel/external/three_with_fbxloader.min.js Loading http://localhost:8080/public/plugins/grafana-Model-panel/module.js Loading plugins/grafana-Model-panel/module
I don’t understand why THREE would not be defined. When I use the same file in my browser it works fine.
Finally, I looked for URLs to put in the src=“” attribute inside a script tag, but I cannot find this for all the libraries I am using. Next to that, FBXLoader.js somehow does not work when it is not in the same file as three.js.
Does anyone have experience with using three.js in a plugin, or with importing files like this? I would like to know how you get the import statements to work.
Thanks in advance!
For anyone who is still struggling with this, I have finally found a solution.
In the external folder, two files are needed: three.min.js and another file (I named this file three_with_fbxloader.js) which contains all the other libraries that use threejs that you need. In this other file, start the file with
let THREE = require('./three.min');
After this, paste all the libraries you want to use. Then, at the end of the file, type
module.exports = THREE;
Then, in your JavaScript file (module.js), start with the following import:
import THREE from './external/three_with_fbxloader.min';
and this should work. I hope that this answer is helpful for anyone having trouble with this!
Kind regards,
Esmee
Hi sir, sorry for dig so back in time.
Can you upload somewhere the two file that you have used?
The “module.js” what file is it?
@Yusseiin is the main plugin entry file. Nowadays since plugins are developed with typescript you will find it as “module.ts” and “module.js” is generated as a built file by webpack which you should not manually modify.
@academo Thanks, i am trying to making three.js working with grafana but it still not working :frowning:
What do you want to visual using three js
@yosiasz any 3d model. STL, STEP, gltf etc.
Can you provide one simple sample we might be able to use dynamic text plugin for this
@yosiasz yes, you can take any element from the three.js github page like:
I want to be able to zoom in, zoom out and rotate the model. i do not need any background or similar. Just the model.
here the example:
https://threejs.org/examples/#webgl_loader_gltf
