Grafana v10.2.0 on a Raspberry Pi 4 running Raspberry Pi OS -
I want to display the status of my thermostats on the time series or (even better) use the status to alter the set temperature. Via IOBroker I set the thermostat status to “off” while the window is open and back to “heat” a few minutes after it is closed.
I would like the set temperature to display 0°C while the status is set to “off”
Everything is logged in an influxdb database. The status is logged as string (“off” and “heat”)
If it is not possible to change the set temperature value, I would just like to display the status as a number on the graph. (1 and 0 for “heat” and “off”) -
Tried finding a solution with google and also asked ChatGPT with no success. Played around with Value mappings but could not find anything useful. -
What happened?
@FeuerFrosch Hey, I’m trying to achieve the same exact thing. But here is what I’ve only achieved:
The “Enums” are duplicated for each TRV, their order is not consistent
Hey @dredo97 , that’s an amazing graph. I found it while on a hunt for a way of turning similar ‘bool as string’-encoded data into a time series graph.
Can you share how you created this please?
