Hi, I’m trying to do something, but can’t manage:
10.2.3 Windows 11 - What are you trying to achieve?
Union data so there line on Time Series is solid - How are you trying to achieve it?
import "strings"
import "date"
applyAggregation = (tables=<-, start, stop) =>
if (uint(v: stop) - uint(v: start)) > (90*24*60*60*1000000000) then
tables |> aggregateWindow(every: 60m, fn: mean)
else if (uint(v: stop) - uint(v: start)) > (7*24*60*60*1000000000) then
// more than 7 days in nanoseconds
tables |> aggregateWindow(every: 10m, fn: mean)
else
tables
sensorList = strings.split(v: "${Environments}", t:",")
lastPointBeforeStart = from(bucket: "Measurements")
|> range(start: date.sub(from: v.timeRangeStart, d: 1d), stop: v.timeRangeStart)
|> filter(fn: (r) => r._measurement == "Measurements")
|> filter(fn: (r) => r._field == "value")
|> filter(fn: (r) => r.machinecode == "${Machine}")
|> filter(fn: (r) => contains(value: r.sensor, set: sensorList))
|> last()
|> map(fn: (r) => ({r with _time: v.timeRangeStart}))
data = from(bucket: "Measurements")
|> applyAggregation(start: v.timeRangeStart, stop: v.timeRangeStop)
lastPoint = data
|> last()
extendedPoint = lastPoint
|> map(fn: (r) => ({r with _time: now()}))
combined = union(tables: [lastPointBeforeStart, data, extendedPoint])
combined
|> yield()
What happened?
The dots should be connected with lines, like in one column. Two lines from begging to the end of the panel.
Anyone can help me?
