I have a config file in the same level as my test scripts. Adding tlsAuth as options directly in the test script works fine and it finds the certificate. However, if I have the same tlsAuth option in a config file, it doesn’t work. I get the following error:
ERRO[0001] tls: failed to find any PEM data in certificate input
Any idea why?
Regards,
Sharath
