I do measurements in different testing installations and on different testing batches.
So I filter the measurement data based on two user defined variables called “_installation_id” and “_batch_id”.
I would like to display the measurements using the “Time series” widget.
For this purpose I created the following sql statement:
SELECT
pot AS "time",
value_desc_varchar AS metric,
val_int
FROM grafana_data
WHERE
pot BETWEEN '2021-07-01 07:00:00'AND '2021-07-01 10:00:00'
AND installation_id=$installation_id
AND batch_id=$batch_id
AND value_desc_varchar IN
'Temp. oben rechts',
'Temp. oben links',
'Temp. mitte rechts',
'Temp. mitte links',
'Temp. unten rechts',
'Temp. unten links',
'Temp. Schornstein'
ORDER BY 1
However the widget only displays my data when I do select the appropriate time filter on top of the page. It seems there is some underlaying filtering based on the time filter lies above the sql statement.
How can I manage to show the content using the static selection above (pot BETWEEN '2021-07-01 07:00:00’AND ‘2021-07-01 10:00:00’) without the need to use the time filter in addition to that?
Using the same timeframe as in the sql statement
Using a different timeframe
