Time Series is rendered incorrectly
As you can see 710,000 is plotted over 2.5m
It looks like you’re stacking the series?
The tooltip shows the value for the yellow time series, whereas the yellow and green together add up to 2.5m. I’m guessing that the value for the green series is 1.79m?
Thanks, I deleted the panel, remade it, all worked.
