Time series Data outside time range
Could somebody help me with Time series graph. My query is this
SELECT
    CONVERT_TZ(Laikas, @@SESSION.time_zone, '-04:00') AS time,
    CAST(stulpelis2 AS float) AS value
FROM
    asedlt_8622.testukas
ORDER BY
    Laikas DESC
LIMIT
    5;
then I run my query, get answer “Data outside time range”, I have attached picture. How solve this problem?
what is @@SESSION.time_zone in relation to UTC?
what timezone is Laikas
if I use this query
SELECT
    Laikas AS time,
FROM
ORDER BY
    Laikas DESC
LIMIT
    5;
Grafana get data
But same query to my mysql get this data
You see different one hour. Why? :slight_smile:
because your Laikas column is 1 hour difference from UTC meaning your Laikas column is not UTC. What time zone are you in ?
What does @@SESSION.time_zone show
I am in the UTC/GMT +1 time zone, while the server is in the UTC/GMT +2 time zone
in that case try ie using of course your time zone
convert_tz(Laikas,'America/New_York','UTC') as time
CET Central Europe Time
MET Middle European Time
no :slight_smile: show next day time :smiley: I left this CONVERT_TZ(Laikas, @@SESSION.time_zone, ‘-04:00’) AS time it working now.
