Thresholds only for Numbers?
I would like to display the state of a sensor with different colors. The value displayed is open or closed.
Have you checked value mappings? You can set mappings like this:
and it should work (case sensitive, so it might need some tweaking). If not, can you share a little more (like screens, the data etc).
it works! I had overlooked that.
Thanks!
