"Third-party cookie will be blocked. Learn more in the Issues tab." browser_source=other line_number=0 source=browser
I am using K6 latest version and updated scripts and customized docker image from k6. Everything is woking fine in my local. If I run with docker image using k6-operator I am getting following error.
My application login is required third party cookies.
level=warning msg=“Third-party cookie will be blocked. Learn more in the Issues tab.” browser_source=other line_number=0 source=browser
Please share If i have to send any additional config options at
export const options = {
  scenarios: {
    ui: {
      executor: 'shared-iterations',
      iterations: 5,
      options: {
        browser: {
          type: 'chromium',
Hi @ppyneni,
Yes, it would be great if you could share with us the test script and the HTML document we can run the script against.
Thanks.
Hi, @inancgumus!
I also reproduce this error (WARN). Can it be disabled?
An example with a website grafana.com:
import { browser } from 'k6/experimental/browser';
    scenarios: {
        ui: {
            options: {
                browser: {
                    type: 'chromium',
export default async function () {
    const page = browser.newPage();
    try {
        await page.goto('https://grafana.com/');
    } finally {
        page.close();
Output:
Third-party cookie will be blocked. Learn more in the Issues tab.  browser_source=other line_number=0 source=browser url="https://grafana.com/"
also curious about this issue
I’m also curious about this issue I’m facing. Any solution or ticket tracking this so far?
Hi @inancgumus, any progress with this? Thanks.
This seems to be generated automatically by Google Chrome. We haven’t yet found a good solution to solve this issue. We’re still looking for a solution.
Cool thanks for the fast response. Cheers
