Hi team,
I want to login in the setup function using a k6 session (httpx) and use that for the rest of the test.
However when using a return value from the setup function and using data in the main function as an argument, it gives an error.
The authenticateFlowWithSession is just a simple login
export function authenticateFlowWithSession() {
const loginSession = new Httpx({
headers: {
accept: "application/json, text/plain, */*",
"Content-Type": "application/json"
let body = JSON.stringify({
username: __ENV.USERNAME,
password: __ENV.PASSWORD
var login = loginSession.post(`${__ENV.URL}/login/authenticate`, body);
var cookie = login.cookies;
let session = login.cookies.PHPSESSID[0].value;
loginSession.addHeader("cookie", cookie);
return { loginSession };
export function setup() {
auth = authenticateFlowWithSession();
return auth.loginSession;
export default function testSuite(data) {
const authenticationData = authenticateFlowWithSession();
const testObject = authenticationData.loginSession;
console.log(data);
console.log(testObject);
They both return an object from the setup function and an object when I do it in the test itself. This can be seen when I console.log them.
"baseURL": "",
"params": {
"headers": {
"accept": "application/json, text/plain, */*",
"Content-Type": "application/json",
"cookie": "PHPSESSID=hnrjkm3g4olal6qvdchnp05n90; SpecialCookie=somecookie"
"tags": {
However when I want to use testObject it in a request like this in the main testSuite function, it works.
var response = testObject.post(`${__ENV.URL}/somerequest`, body);
When I want to do it from the setup function in a request like this also in the testSuite function, it does not work.
var response = data.post(`${__ENV.URL}/somerequest`, body);
it returns an error.
Object has no member 'post'
What am I missing or doing wrong?
Thanks in advance.
