I’m concerned about deploying a Tempo cluster on two host machines (52 and 151) using Docker Compose and network hosting. The Tempo.yaml file is as follows:
server:
http_listen_port: 3200
grpc_listen_port: 9096
distributor:
ring:
kvstore:
store: memberlist
instance_addr: ${ip_52}
instance_id: "tempo-52"
receivers:
otlp:
protocols:
http:
endpoint: 0.0.0.0:43180
grpc:
endpoint: 0.0.0.0:43170
ingester:
max_block_duration: 15m
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 2
address: ${ip_52}
compactor:
compaction:
block_retention: 24h
compacted_block_retention: 1h
ring:
kvstore:
store: memberlist
storage:
trace:
blocklist_poll: 15m
blocklist_poll_tenant_index_builders: 1
backend: s3
block:
bloom_filter_false_positive: .05
wal:
path: /var/tempo/wal
s3:
bucket: ${bucket}
endpoint: s3.amazonaws.com
region: ${region}
access_key: ${access_key}
secret_key: ${secret_key}
prefix: observer/
insecure: true
local:
path: /var/tempo/traces
pool:
max_workers: 100
queue_depth: 10000
overrides:
defaults:
metrics_generator:
processors: ["service-graphs", "span-metrics", "local-blocks"]
generate_native_histograms: both
metrics_generator:
registry:
external_labels:
source: tempo
cluster: distributed
storage:
path: /var/tempo/generator/wal
remote_write:
- url: http://${mimir-host}/api/v1/push
send_exemplars: true
traces_storage:
path: /var/tempo/generator/traces
memberlist:
node_name: "tempo-52"
join_members:
- ${ip_52}:7949
- ${ip_151}:7949
bind_port: 7949
bind_addr:
- ${ip_52}
advertise_addr: ${ip_52}
advertise_port: 7949
gossip_interval: 500ms
The tempo.yaml file on machine 151 is similar to the one described above, only the IP addresses are different.
After deployment, I found that on ingester/ring, I can only see various data, but no cluster data is displayed.
memberlist:
When I send a trace to 52 tempo, I can only find the corresponding trace from 52 tempo, but not from 151.
I want to achieve the effect of a cluster. Can anyone help me see what the problem is?
