I encountered a failure while attempting to render an image using an HTML graphics panel and utilizing MQTT as the data source after upgrading to version 10.2.2.
version before : v.9.2 upgrade to version 10.2.2
version image render : 3.6.4
I have seen the same issue which I tracked down to first appearing in 10.2.0:
Initial config:
Grafana 10.1.5
grafana-image-renderer @ 3.9.0
vertamedia-clickhouse-datasource @ 2.5.4
Log output on successful image rendering:
Dec 6 11:14:18 test grafana[18238]: logger=rendering renderer=plugin t=2023-12-06T11:14:18.467932854Z level=info msg=Rendering path="d-solo/wom-ext-5minagg-rssac-report/rssac-reporting?orgId=1&from=1701216000000&to=1701302400000&var-Server=IMRS&panelId=1&width=1000&height=600&tz=UTC&theme=light"
Dec 6 11:14:20 test grafana[18238]: logger=live t=2023-12-06T11:14:20.660721417Z level=info msg="Initialized channel handler" channel=grafana/dashboard/uid/wom-ext-5minagg-rssac-report address=grafana/dashboard/uid/wom-ext-5minagg-rssac-report
After upgrading to Grafana 10.2.0. Image rendering then fails with error handler=notfound followed by 404 and eventual time out. Log output:
Dec 6 11:22:04 test grafana[1745]: logger=rendering renderer=plugin t=2023-12-06T11:22:04.493135044Z level=info msg=Rendering path="d-solo/wom-ext-5minagg-rssac-report/rssac-reporting?orgId=1&from=1701216000000&to=1701302400000&var-Server=IMRS&panelId=1&width=1000&height=600&tz=UTC&theme=light"
Dec 6 11:22:06 test grafana[1745]: logger=context userId=0 orgId=1 uname= t=2023-12-06T11:22:06.312343443Z level=info msg="Request Completed" method=GET path=/stats/public/plugins/vertamedia-clickhouse-datasource/module.js status=404 remote_addr=[::1] time_ms=11 duration=11.885544ms size=38867 referer="http://localhost:3000/d-solo/wom-ext-5minagg-rssac-report/rssac-reporting?from=1701216000000&height=600&orgId=1&panelId=1&render=1&theme=light&to=1701302400000&tz=UTC&var-Server=IMRS&width=1000" handler=notfound
Dec 6 11:22:06 test grafana[1745]: logger=plugin.grafana-image-renderer t=2023-12-06T11:22:06.322564005Z level=error msg="Browser console error" msg="Failed to load resource: the server responded with a status of 404 (Not Found)" url="http://localhost:3000/stats/public/plugins/vertamedia-clickhouse-datasource/module.js?_cache=2.5.4"
Dec 6 11:22:06 test grafana[1745]: logger=live t=2023-12-06T11:22:06.342323153Z level=info msg="Initialized channel handler" channel=grafana/dashboard/uid/wom-ext-5minagg-rssac-report address=grafana/dashboard/uid/wom-ext-5minagg-rssac-report
Dec 6 11:23:04 test grafana[1745]: logger=plugin.grafana-image-renderer t=2023-12-06T11:23:04.830431143Z level=error msg="Error while trying to prepare page for screenshot" err="TimeoutError: Navigation timeout of 60000 ms exceeded\n at Timeout.<anonymous> (/snapshot/src/node_modules/puppeteer-core/lib/cjs/puppeteer/util/Deferred.js:27:33)\n at listOnTimeout (node:internal/timers:564:17)\n at process.processTimers (node:internal/timers:507:7)" url="http://localhost:3000/d-solo/wom-ext-5minagg-rssac-report/rssac-reporting?orgId=1&from=1701216000000&to=1701302400000&var-Server=IMRS&panelId=1&width=1000&height=600&tz=UTC&theme=light&render=1"
I have this issue on 10.2.2 with specifically the briangann-gauge-panel. Other panels render correctly.
logger=context userId=0 orgId=1 uname= t=2023-12-18T11:37:16.254392342Z level=info msg=“Request Completed” method=GET path=/api/live/ws status=-1 remote_addr=[::1] time_ms=2 duration=2.332682ms size=0 referer= handler=/api/live/ws
logger=context userId=0 orgId=1 uname= t=2023-12-18T11:37:16.578653497Z level=info msg=“Request Completed” method=GET path=/grafana/public/plugins/briangann-gauge-panel/module.js status=404 remote_addr=[::1] time_ms=7 duration=7.418371ms size=42147 referer=“http://localhost:3000/d-solo/26a-V5Wiz/<–removed–>?from=now-24h&height=140&openVizPicker=&orgId=1&panelId=17&refresh=30s&render=1&theme=light&to=now&tz=Europe%2FLondon&width=140” handler=notfound
logger=plugin.grafana-image-renderer t=2023-12-18T11:37:16.582067761Z level=error msg=“Browser console error” msg=“Failed to load resource: the server responded with a status of 404 (Not Found)” url=“http://localhost:3000/grafana/public/plugins/briangann-gauge-panel/module.js?_cache=2.0.1”
After some debugging into the GET requests made during image rendering it became clear this was related to the use of a sub path to server. By altering our configuration we were able to get image rendering to work again
We set our Grafana servers up several years ago to serve fro a sub path called stats and we also use an nginx reverse proxy. Our original configuration for nginx used something like the following:
location /stats {
proxy_set_header Host $http_host;
proxy_pass http://127.0.0.1:3000/;
rewrite /stats/(.*) /$1 break;
And in our grafana.ini file we had:
root_url = https://<domain>/stats
;serve_from_sub_path = false
On 10.1.5 the call to GET the plugin (which worked) was:
/public/plugin/vertmedia-clickhouse-datasource/module.js
But on 10.2.0 this changed to the following which failed:
/stats/public/plugin/vertmedia-clickhouse-datasource/module.js
After updating our configuration in the following way we are still serving from a subpath but now the image rendering works.
nginx configuration to match the suggested mechanism described on this page that does not require a rewrite Run Grafana behind a reverse proxy | Grafana Labs i.e. in our caseupstream stats {
server localhost:3000;
server {
location /stats/ {
proxy_pass http://stats;
grafana.ini file to have the following:root_url = https://<domain>:3000/stats
serve_from_sub_path = true
The documentation page states
If your Grafana configuration does not set
serve_from_sub_pathto true then you need to add a rewrite rule to each location block:
however making these changes to my updated (working) configuration broke image rendering again. So it seem there is issue with 10.2.0 + later versions and this configuration.
My setup is similar, except I’m using apache as the reverse proxy. That server_from_sub_path configuration has caused me issues in the past - another grafana update a couple of years ago. I originally has it set as true, then image rendering broke and I set it to false which fixed the issue (despite the fact I am serving from a sub path - https://myhostname.me/grafana). It never made sense to me at the time, but as it fixed the issue I never bothered following up further.
As I mentioned in my earlier post, I only have issues with one panel type though…
Thanks all for creating this post and providing very detailed insights about it (especially @sdsin
Though I am not an expert with the Image rendering component but I do know it causes a lot of configuration issues (breaks a lot with a new version).
As it seems that you have narrowed it down then I would propose and appreciate it if you could open a bug report about this in our official GitHub repository using this link.
Provide all the information (you can simply copy/paste your data + screenshot from here to there).
Lastly, paste the link to your GitHub issue here in this post so that all other community users can also track it. I will also add more additional information to it ![]()
@usman.ahmad Thanks for the feedback - I will go ahead and create a bug report but I also wanted to add to the discussion here that with my working configuration, an upgrade to 10.2.3 breaks the image rendering in a different way ![]()
When trying to generate an image using the Direct link rendered image link on the Share dialog I now get an immediate 404 error in the browser. This is because in 10.2.2 that link contained the subpath e.g.
https://<domain>/<sub_path>/render/d-solo/...
whereas on 10.2.3 it does not:
https://<domain>/render/d-solo/...
Note that obtaining the image with a curl command or browser request with the correct path still works on 10.2.3, it is just the target of that link that is broken.
With upgrade to 10.4.2, the issue I had with the briangann-gauge-panel and using a subpath and apache reverse proxy has been fixed. Thanks!
