the tags that appear in the body.EvalMatches.tags are NOT what i’ve specified in the Alert configuration UI.
they are the cloudwatch metric ‘Dimensions’ from the metric data (which is cloudwatch).
i really want the tags i specify in the UI in order to drive custom alert processing.
by the way, json can be entered in the message and parsed out, but i’d prefer to use the Tags.
i guess i will report as a bug if there is no general response from the ‘community’.
i reported it as a Bug.
appears it was fixed in version 6.4.
This still doesn’t work for opsgenie notifier as per the latest stable release (6.5.2). But I’ve found this working fine for the master branch. Just FYI
