Is it possible add tags to groups in k6 or its limited to requests and checks alone?
Hi @kavinarvind
Do you refer to url grouping, which is doable, or to adding tags to a group?
What is possible with tags is described in the k6 tags documentation. Can you further detail your concrete use case? An example can help us see if the documentation should be improved, in case what you need is already doable, or if it’s a new feature.
Cheers!
