“Is there anyone using the Status Panel with a Zabbix Data Source? I can not understand how to make it display the results of my query. The same query works on a singlestat and as far as I can tell there seems to be a problem with the plugin when it works with the Query Mode=”text”. If anyone is doing this correctly, please help me!”
Not sure I can help you, try to ask Status Panel developers.
