Sonicwall Firewall Dashboard
    I’m using Grafana server version 10.3.3
    To build a Sonicwall Dashboard
    I am using snmp exporter to poll my sonicwall firewall. The generator had trouble with the loaded sonicwall mibs and couldn’t walk the OID’s so I had to use the OID Alias Names instead. They are;
    • sonicCurrentRAMUtil
      - sonicMaxConnCacheEntries
      - sonicCurrentConnCacheEntries
      - sonicCurrentCPUUtil
      - sonicNatTranslationCount
      - sonicCurrentManagementCPUUtil
      - sonicCurrentFwdAndInspectCPUUtil
      - snwlSysModel
      - snwlSysSerialNumber
      - snwlSysFirmwareVersion
      - snwlSysROMVersion
      - snwlSysAssetNumber
Could someone help me build a dashboard with these metrics?
Welcome @mbplaframboise
I also have a SonicWall (model TZ350). Which model do you have?
I am happy to collaborate with you and create a dashboard. Which time zone are you in?
Hi! That’s great thanks. For security purposes I’d rather not share my model number, but would love to collaborate with you. I’m in the EST time zone. How about yourself? Which time zone are you in?
Yes, I am in EST (Detroit). I will send you a message with some questions, next steps, etc. and once this whole thing is working, we can publish the solution to play.grafana.org, write a blog post, share here, etc.
That sounds great! I live close to London Ontario, in Canada.
Hi @grant2 and @mbplaframboise
This thread is exactly what I was looking for — thanks for starting it :+1:
I’m also running a SonicWall firewall and using SNMP Exporter + Grafana to collect similar metrics (CPU, RAM, connections, firmware info, etc.).
If a dashboard was created as part of this collaboration, would you be willing to share the Grafana dashboard JSON (or publish it on grafana.com / play.grafana.org)? It would be extremely helpful for others like myself trying to build a SonicWall-focused dashboard.
Happy to test it, provide feedback, or contribute improvements if helpful.
Thanks again!
Do you have Dash for SW TZ 670
