i have Grafana 7, installed and configured and it works correctly. Now I want to install Grafana 11 and use it instead of 7. When it comes to contact point I get always the same error msg despite i tried everything. in the grafana.ini i changed the values like this :
smtp:
enabled= true
host= localhost:25
skip_verify= true
from_address= admin@grafana.localhost
from_name= Grafana
when i want to send a test mail i get this error msg:
Failed to send test alert.: failed to send notification to email addresses: xxxx@xxxx.it: dial tcp [::1]:25: connect: connection refused
