SMTP Configuration after Prometheus and Grafana installation with Helm
I have installed Prometheus and Grafana on an AKS cluster using Helm, while setting up email alerting, there an error that states; “SMTP not configured, check your Grafana.ini config file’s [smtp] section” .
I will be very grateful for someone to help me and with a way forward to solve this issue.
Hi @kings620,
Welcome to the :grafana: community support forums !!
The SMTP is enabled by default in the Grafana configuration. You need to enable it via Environmental variables to send out alerts.
Please have a look at this post which is similar to your question as it defines all the required ENV Variable parameters required to make it work.
Let us know if this helps. :slight_smile:
Hi, I am also facing same issue anyone please help me out, how to configure smtp in grafana
