Hello All,
I’ve been trying to debug an issue and just noticed when using a grafana dashboard variable on a panel takes significantly longer on generating panel data vs just inputting the regex in the influxdb query in the panel itself. Difference is somewhere like 5-10 minutes for the variable and a few seconds for the query
Grafana 6.3.5
Influx 1.7.10
Setup 1 - Variable - Query - InfluxDB data source - about 10 minutes to load panel
variable
select distinct(fruit) from data where (“fruit” =~ /^apple/)
Panel Query
select distinct(fruit) from data where (“fruit” =~ /^variable/)
Setup 2 - No variable used, just the influxdb query configured in the panel
Setup 2 only takes a few seconds, whereas setup 1 can take up to 10 minutes.
I also tried changing the variable to a custom definition and it seems to take just as long as setup1
Any help is appreciated, thank you!
