I’m new to Grafana and Prometheus and I want to try something.
I installed it yesterday on my docker environment on a pi. I have used a tutorial to set it up. I have used dashboard id 1860 to monitor my pi.
I now have a great looking dashboard. I only have a question for the networking part. It is now showing all network interfaces that are being used. So also the docker virtual interfaces. How can I only show traffic from eth0?
This is the default query : irate(node_network_receive_bytes_total{instance=“$node”,job=“$job”}[$__rate_interval])*8
I have tried to add node_network_iface_id{device=“eth0” after the 8 with a space but that didn’t work. Is it even possible to filter on only interface eth0?
Sorry for the maybe simple and stupid question. ![]()
