I’m trying to grab a client id/secret combo from vault and pass it into grafana via the helm --set flag:
helm upgrade \
-i loki \
-n loki --create-namespace \
grafana/loki-stack \
-f values.yaml \
--set grafana.'grafana\.ini'.auth.okta.client_id="${OKTA_ID}" \
--set grafana.'grafana\.ini'.auth.okta.client_id="${OKTA_SECRET}"
however, it doesn’t seem to set the two fields properly. when I add id/secret via value.yaml file directly, it works as expected.
is this behavior expected or is the set command incorrect?
thanks!
