k6 had written datas to db, why select * form it is null ?
Hi @sunnini,
in that way, you’re not querying the k6
database. You’re already set the database with the use k6
command.
What you want now is querying the series
or measurements
so you have to try with show series
or show measurements
Thanks @codebien , I got it.
