Hello team,
In my code , i have 2 HTTP request
1 - the first HTTP.post request makes an call to endpoint to get accessToken
I then store that access Token in a variable and then make another HTTP.get call with that accessToken as header
When i run end to end in my local with k6 command , i am able to see the result as expected
But when i run the same command in cloud , it is failing
The second HTTP.get call is failing but HTTP.POST is passing.
I read few articles on how to ignore HTTP call on my code but did not get the solution
Is there a way to run only HTTP.get and avoid HTTP.post in my script
Is there a reason why my second HTTP.get call is failing in cloud whereas passing in local machine ?
I suppose those endpoints are public so should not be an issue
