Hello, I have a python script and a javascript script that build a flatbuffer and converts it to binary. I need to run one of these scripts from inside the k6 default function and use it’s output. For example, lets say I have a javascript script called “test.js” and it returns a value “123.” I need to be able to call that “test.js” from inside the K6 default function and be able use the “123” value and send it over a websocket. Is this possible?
Hi @mipeters , welcome to the community forum!
You can run external programs with the GitHub - grafana/xk6-exec: A k6 extension for running external commands. extension.
hello.py:
print("123")
script.js:
import exec from 'k6/x/exec';
export function setup(){
console.log(exec.command("python3",["hello.py"]));
export default function () {
console.log("iteration")
The output of the ./k6 run -i 10 script.js command (where k6 is the custom k6 binary with xk6-exec built into) is:
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: script.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 10 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0000] 123 source=console
INFO[0000] iteration source=console
█ setup
data_received........: 0 B 0 B/s
data_sent............: 0 B 0 B/s
iteration_duration...: avg=1.43ms min=8.23µs med=8.87µs max=15.6ms p(90)=48.73µs p(95)=7.82ms
iterations...........: 10 618.017599/s
running (00m00.0s), 0/1 VUs, 10 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 00m00.0s/10m0s 10/10 shared iters
I hope it helps
