Running an archive with new tags removes the tags from the archive
Hi, I’m creating an archive with a tag like this
k6 archive --tag foo=1 loadtest.js
which adds the foo as a label to emitted metrics when I run the archive, as expected.
But when I run the archive with an additional tag, like this
k6 run --tag bar=1 archive.tar
the foo label is removed, and only the bar label is present on the metrics.
I see in the documentation for the archive command that cli flags can be overridden when running the archive, which makes sense to me for other cli flags. But I expected that adding tags to an archive before running it would append tags, not completely remove the tags from the archive. Is this the expected behavior?
Thanks,
Kevin
HI @kshawroblox, welcome to the community forum!
Options in k6 are overridden by layers - if you configure it different layers , only the “latest” layer is the one that takes effect.
This was/is discussed here - as explained there, there are other considerations. You are welcome to add your use case and vision there as well.
At this point with k6 v1 released thsi also will be a breaking change that will need to be pushed until v2. But it is also the kind of thing that will be much more easy to get merged … for v2, instead of having to make it pre v1.
Hope this helps you!
Thanks for the response and linking me to that issue! My use case is pretty similar to yorugac, I have tags set when creating an archive, and then pass the archive for distributed execution and add new tags before running it. I’ve found a workaround so this is not completely necessary for me, but my suggested solution would be the same as yorugac’s if this does make it in v2.
